Node 2i sound volume control and RCA output quality?
    Hello there,
    It shouldn't affect the quality; most often I see users use Fixed Output to leave all volume control to one device, but if you find using both variable volume on your NODE and your external device ultimately have a better output, you should be good to go.
  • paul arango
    I'm thinking about using the Node2i with an external DAC and it will be much more convenient to keep using the Node2i as the overall volume control.  How good is the digital volume control on the Node2i?  Is the output 24 bits?  Any other suggestions to minimize jitter?
