Scale noise on pause/play node2i headphones
4 comments
    Hello,
    Hard to say. I run the headphone out of my NODE to a small amp and haven't heard any sort of 'feedback' sounds when adjusting the volume or pausing/playing. I would recommend testing with another pair of headphones/earphones just to confirm (could be high sensitivity).
  • tranbert
    Tested with  senheiser momentum + akg k280 + bose q15 + akg k451 same problem...
    edit  : problem is the same when skipping next track (little fade out)  or manual volume level adjustment...
    edit 2 : on bluetooth, no problem...
  • Sam R.
    Interesting. Please send a diagnostics log to our support crew (via the BluOS app under Help > Send Support Request) so they may look into this further.
  • tranbert
    OK... Thanks.
