Node 2 Static, distortion and drop outs
    Hi Ted
    Replace your COAX cable. If problems persist, please select Help, Send Support Request in the BluOS App and be sure to mention the make and model f your DAC,
  • Ted Baca
    Tony
    Thank you for your response. I have tried a different cable as you suggested. I will try to send a Support Request. I have been discussing this matter with other and they think it is the software I have version 3.20.45 and one of the users said he had 3.20.49 and has resolved his concerns. I am hoping that the next update will correct the issue. I have tried to initiate a update but I get the response that there is none available. I am not sure when my current upgrade was installed but, I do know I wasn't experienceing any issues prior to that milestone. So I am hopefull 3.20.49 will resolve these issues, once available.
    Thank You
