stuttering wired noise from one channel on Powernode
AnsweredHi, I've started experiencing weird noises from one channel on my Powernode, and it's just the left channel (and not the speakers).
It starts as soon as Powernode turn on, so without opening the bluos app, but weirdly now when I open the bluos app and there's a change in track, it's accompanied by some scratchy noises as well.
I'd appreciate some help. Thanks
Swap the speaker leads at the POWERNODE (so left become right and right becomes left) and see if the noise moves.
Yes it moved to the right speaker, so it's definitely the Powernode.
You could try powering off (remove the power lead) for 5 mins and see if that help.
If this does not help then immediately after the noise use the BluOS app and select Help…Sebd Support Request.
It does not help, I tried to reboot, tried to reboot my network, and reset my powernode 3 times.
I did send support request, her answer was to contact an Australian warranty service to sent it to them for evaluation (I bought the Powernode used).0 -
You are in good hands then.
Not really, I can't use the warranty as I'm the second owner...
They won't honour the warranty as I'm the second owner, so I was hoping to find some solution on the forum :)
7 comments
