Build Home Theater with Node2i and Flex
    Hi Rob
    Home Theatre Grouping is only available with the POWERNODE 2i w HDMI, POWERNODE N330 or SOUNDBAR (all models) as front channels require DOLBY decode capability. Though the NODE N130 does have an HDMI port, it does not feature DOLBY decode.
    For more details on Home Theatre Grouping combinations, please see; https://support.bluos.net/hc/en-us/articles/360043743094
  • Rob Huikeshoven
    Thank you for your reply @Seppi.
    Can you elaborate why the PowerNode would be necessary? I use active front speakers, so I don't need power from the PowerNode, the speakers are connected using Coax digital OUT on de Node 2i currently.
    The PowerNode nor the Soundbar have such OUT port.
