BluOS Loses Network Connection With Player After Session Idle Overnight
6 comments
    Hi Keith
    I have escalated your issue to our Support Crew for a closer look.
  • DeckardWill
    Keith there is a long thread on this on the General forum. You are not alone, Bluesound have acknowledged a firmware bug and we're all awaiting a fix.
  • Oliver M.
    Woke up this morning and both devices (Node and Node 2i) no longer recognizes the wifi network. I've done factory reset, deleted the BluOs app, and nada! I have been experiencing the same issue the past few months where I'm having to unplug-plug the unit to get recognized - not today.
    How can we get help regarding this? I've enjoyed the 2i for 4 years hence buying the 2nd unit (NODE). Hope these units are not bricked.
    Thanks in advance.
    Hi Oliver
    support@bluesound.com is your fastest and easiest way to help
  • Oliver M.
    Thanks Tony! Email sent as advised.
  • Adrian Ennis
    I seem to be having the same issue.
