Same problem 3 years later
    Hi Steff
    In reviewing your history, we are unable to locate a Support Request from you using the contact information you made this post with. We do recommend you open a new request by selecting Help, Send Support Request. Before you do though, check your Panasonic TV settings. If you are hearing an echo, your TV speakers are not disabled. Those should be auto-disabled if connected properly using the ARC output of your television.
