Lack of clear solution from Bluesound to the Soft touch material issue.
    Mark T.
    Sr. Support Crew Member
    We would like to sincerely apologize for any inconvenience caused by the stickiness of your older Bluesound devices. This is unfortunately a common issue with rubberized materials and we have also experienced similar problems with other non-Bluesound products.
    While we do not typically recommend third-party products, we have seen great results with an electronics safe degreaser that is residue-free. We believe this may help remove the sticky residue from your player. Additionally, we have also heard positive feedback regarding the use of Polytrol here in this community thread - https://support1.bluesound.com/hc/en-us/community/posts/8494262325527/comments/8503586349975
    We are pleased to inform you that this issue has been addressed in our new product lineup, and we are confident that our current offerings will meet your expectations in terms of quality and durability.
    Lastly, to ensure that you receive the best possible assistance, we recommend that you reach out to your local Bluesound dealer.
Post is closed for comments.
