Node external dac volume control
AnsweredHello, it is better to control volume in bluos app? or use fixed volume output and let external dac do control with dac+preamp mode. Topping E70 dac
Just uses what’s most convenient, if the DAC has other sources then it’s probably better to use the volume control there. If just the one source then use variable on the NODE and control it from there.
I just replied to your other post but you deleted it.
-1 -
Sorry noticed it was 3 year old post in ipad/iphone category.
