NAD C368+MDC BLUOS 2I - AIRPLAY PROBLEM
AnsweredHi,
I've got problem with connecting to NAD C368+MDC BluOS 2i through AirPlay with my iPhone or iPad. Access to other Airplay devices (e.g. Apple TV, Sonos Beam) works with both devices. However, the NAD C368 does not appear in the Airplay selection menu.
I've upgraded firmware to the newest one (MCU 1.75 / VFD 1.22 / BT 1.26), restarted devices and still the same. I have also updated the Bluos software to the latest version.
There's no visible NAD or BluOS option in my AirPlay menu.
I can connect my NAD through Bluetooth or BluOS app, so the hardware works fine. The C368 (serial number: H6ZC368G07707) is connected to the network by cable (no WiFi)
Any solution?
Hi Roger,
Try rebooting your entire network and see if that helps with your issue. If issue persists, please reach out to our support crew by sending a support request using the BluOS app or by emailing us at support@nadelectronics.com -
Did you ever solve this? I'm having the same problem. I can play Bluetooth and Spotify. But can't Airplay anything. There's nothing in my Airplay menu to go to my NAD c368.
