The sound with ethernet cable is better than with wifi
AnsweredThe sound with ethernet cable is better than with wifi and I have verified it. I would like to know why this happens since with my PC this does not happen.
Mira aquí.
https://theaudiophileman.com/node-streamer-review-bluesound/
"Now this first point is also a general tip but it’s just as important for the Node. If not more so. This box will produce a satisfactory audio output via Wi-Fi but if you want a sense of quality from the Node then I highly recommend hooking it up to the wall and listening in wired mode via Ethernet. "
LAN or WiFI is the transport layer. With CRC-checks, they will receive the same stream with no errors.
I wonder if you can see the difference in images on your monitor too.1 -
Well, my ears tell me that the cable connection has more power in the bass and the highs and mids are more crystal clear. I didn't believe it until I tried it on my Node N130. I can't show you graphs, I'm sorry but that's the reality. And since I have to take a cable of almost 3m to the Node from my router to better listen to my music, I am going to return the Node where I bought it since I have time to do it. Luckily I've tried it, it's a pity that's the way it is.0
