TV sound stutters
12 comments
    Mark T.
    Sr. Support Crew Member
    I have escalated your feedback to a support ticket. A member of our support team will reach out to you soon.
    Thanks for #LivingHiFi
  • Diederik
    Exact same issues over here!
  • Sebastian
    Hello, I do have the same problem. Is there already a working solution. It is so annoying to the point that I already plugged out my flex 2i rear speakers when I watch a movie. Thanks
  • Diederik
    Mine is recently send to the Bluesound repair center, it should be back this or next week. It had something to do with the HDMI they said.
  • Sebastian
    Thanks, would be great if this can solve the problem!
  • Geoff Dorn
    If you get a solution please post it here. I’ve been going in slow painful circles with support and getting Absolutely no where.
  • Diederik
    After all they send it to the Bluesound center in Denmark where they completely renewed the HDMI part inside. And that finally helped.
    Too bad it came damaged back (....) they probably dropped it. But the guy (Edwin) from Hifi Klubben Apeldoorn was so kind to give me a complete new soundbar! Great service.
  • Sebastian
    Okay, thank you, that's great to hear. Maybe this will solve our problems as well. I will write a ticket to bluesound directly. Nobody from bluesound seems to respond here anymore.
    Hi Sebastian
    Support@bluesound.com or Send Support Request in the Settings of the App should always be your plan.
    This feedback channel is not meant as true Technical Support.
  • Kris Broodcoorens
    Hello,
    After the update to Bluos 4 the issue was mysteriously resolved. In return I got some minor issues back although the Home Cinema mode is working much better.
    In regard to the HDMI-solution: I also had this issue with a previous version of the soundbar without hdmi.
    Kind regards,
    Kris
  • Sebastian
    thank you. I will do so. @Kris, I already have blueOS 4 but the issue still occurs. Good though that it worked for you.
    Best regards
    Sebastian
  • Kris Broodcoorens
    Unfortunately after the last bluos-update problems got worse again. Surprisingly, this time while playing music through Spotify: flex start to stutter and after a while music stops completely.
