PULSE Flex 2i Speakers Dim LED light
AnsweredIs it possible to dim/control LED light on my Flex 2i speakers like I do on my Soundbar+ it is pretty bright light
Absolutely, in the BluOS app select Settings…Player…Indicator Brightness.
You can choose between bright, Dim and Off.
Edit, if used as surrounds I think you have to remove them first, make the change and add them again.
well that only applies to my soundbar+
am I missing something somewhere?
ahh your "edit" will do the trick I guess, thanks
