The audio clips in PowerNode 2i and is connected via HDMI eArc cabel from a Samsung TV (model QE65Q90TATXXC)
    Mark T.
    Sr. Support Crew Member
    Have you tried replacing the HDMI cable? Please confirm if the HDMI cable you are using is a "Certified HDMI Cable".
    If you have checked this and still experiencing issues, please send a support request to support@bluesound.com or using the BluOS app and a member of ourĀ support teamĀ will be happy to assist you.
    Thanks for #LivingHiFi
  • JG.B.
    Hi Jan,
    Had similar issue and have been told to go in the TV audio settings and ensuring that the HDMI output is set to PCM/PCM Stereo format. That is because our Bluesound Players will only process/decode PCM/PCM Stereo audio format.
    Hope that helps
