Blue sound Node N130 juttering while listening.
    Seppi Evans
    I would reboot your router, then check what download speeds you are getting on a phone / tablet connected to your Wi-Fi. Both Amazon Music and Tidal are higher resolution so they need a reasonable amount of bandwidth to play, with Tidal you need around 20Mbps.
    If this does not help using the BluOS app select Help…Send Support Request immediately after the stuttering.
