Option for: led on while playing, off when not playing
6 comments
    Mark T.
    Sr. Support Crew Member
    I have forwarded your feedback to our quality assurance and development team for future update consideration.
    Thanks for #LivingHiFi
  • krang
    Node/Powernode/Speakers are blinking when muted which is helpful for me.
    Still I think blinking is not ideal (it's rather disturbing when you have multiple speakers in view and they all blink at different rates) but what you suggest would be way better. Blue when actually the DAC sees music (or via whatever measure) and an previously unused color if inactive, purple?
    I also see that this will be forwarded to the product development folks. An image of said Bluesound department can be found under /dev/null
  • Hansroggen
    Thanks Mark!
  • Sergio Lupi
    Come on Bluesound, pleeeeease.
    Sometimes I turn on my amp only to find out that the Node had been streaming the whole night.
    Really, it only takes a very little software update to change the led lighting scheme to show when the Node is playing or not.
    It is very annoying that a 600 dollar device does not tell you if it's on or off.
  • Derek Stratton
    I get around this by setting an alarm that at midnight starts a playlist that contains only one 10-second track (from the library) called "silence". In reality, any single mp3/wave/flac file will do; the lower volume the better. (It's well worth the time to learn to use Audacity).
    Every day at midnight the alarm replaces the play queue with this playlist, then (by default) stops when it is done.  Only downside (but easy to live with) is that the old play queue is lost.
  • Stefan c
    I agree this is one of the most annoying issues with the player. Even more annoying is though that support does not care to provide any feedback or acknowledgement of the issue. Is it a software change (future update) or hardware (future model)?
