Connect Node to Sennheiser Ambeo Max AND to Amplifier to simultaneously drive patio speakers'
AnsweredI would like to connect a Node to BOTH a Sennheiser Ambeo Max soundbar for inside AND to an Amplifier to simultaneously drive patio speakers outside. Connections will be wired. Is this possible? If so, how?
Thank you Seppi! If there is delay, does Node allow me to select either just the soundbar or just the amplifier? For example, assuming delay, I'm outside, so music only plays through amplifier or I'm inside and music only plays through soundbar.
Thank you!
Just crossed my mind... Would the same delay issue apply to the PowerNode & the Soundbar?
