Controlling the volume of my integrated amplifier with the Bluesound RC1
AnsweredHi. Is it possible to programe the Bluesound RC1 remote so I could control the volume of my integrated amplifier .
Would be neat and convenient to use in conjunction with the Node. It would have to be possible to program the codes for volume from my integrated to the RC1 remote.
The RC1 is not a universal remote control and has no learning facility, in Bluesound hardware it’s the hardware that learns the IR codes (or has them preconfigured in the case of the RC1) so look to see if your amp has a IR learning function.
If you used variable output you could control the volume out level of the Node with the RC1 but that then gets complicated with two volume controls in play but that does work for some.
