Unable to get sound from vault 2i
AnsweredUnable to get sound from vault 2i on my MacBook laptop on the same network
How is the MacBook connected to your VAULT?
You know that you can also do network share your Music Library from your MacBook to the BluOS app? File Sharing - macOS – The BluOS Support Crew
You can also reach out to our support team using the BluOS app. This way our support team can analyze the diagnostic logs attached on your support ticket.
Thanks for #LivingHiFi
