Bluesound Node 2 delay?
    Avatar
    Brandon C.
    Hi Miro,
    If you are using the Analog or Optical IN connection of the Node 2 for the T.V Audio and then going to speakers or an amplifier and then speakers you should not notice any delay / lag.
    If using Digital IN for these speakers is an option then you may notice some delay as the internal DAC of those speakers will be converting the signal and we can not account for external devices conversion as it is happening later down the chain after the audio has left the Node 2.
    That being said we are not certain you will experience any issues, it may be best to contact Dynaudio regarding this.
    Comment actions Permalink
