Pulse Sound Bar with TV Mount and Universal Soundbar Bracket
AnsweredHi, We would like to mount our TV and Bluesound soundbar to a full-motion tv mounting bracket. I'm hoping to use a universal soundbar bracket (i.e. https://www.amazon.com/dp/B00823170Y/ref=psdc_297859_t3_B00IEM6DBG) to attached the Bluesound soundbar.
I think I can in conjunction with the soundbar wall-mount brackets. Could someone confirm that this is possible?
Thanks in advance.
Hi Lyle,
The Bluesound Soundbar does not have mounting screw holes, instead it uses a slot based system for mounting.
We recommend against using an articulating bracket as the Soundbar has a built in gyro to ensure the left and right are consistent whether or not the Player is right side up, or mounting upside down depending on the needs and accessibility of the IO.
We recommend using the TS100 : http://www.bluesound.com/products/ts100-soundbar-stand/
Otherwise speaking to your local Authorized Bluesound Dealer may provide you with some other options for mounting. -
Thanks but the TS100 is not an option for us. I was hoping to use the Soundbar wall mount kit in conjunction with a tv mounting bracket + some sort of universal soundbar bracket. This is for my wife's studio and any visible cords trailing from TV to soundbar will be a problem.
I've talked to the dealer but they don't have experience with the Pulse Soundbar - we would be their first sale.
I am about to have the same problem and if the Soundbar can't be mounted on a full motion Sanus wall mount, then bluesound not an option. Is there still no bracket, adapter, or mounting piece that will allow this? The documentation is not clear as to exactly how the unit is mounted using the slot based system. If this can't be done it's a huge oversight from Bluesound, and will limit our ability to install the multiple nodes and NAD componenets to run our home system.
We are trying to mount it to a Sanus VLF728 full motion wall mount with the SAS-B1 soundbar adappter
Hi Jeffrey
The PULSE SOUNDBAR does come with a Universal wall mount and should work with most conventional mounting systems.
4 comments
