2.12.00 causing sound issues
7 comments
    Avatar
    Hi All
    Thank you for your patience - we will be issuing a software update today for BluOS 2.12.1 which resolve audio output issues on some radio based services such as iHeartRADIO, CALM Radio, Slacker and some others. Thank you fro your patience and for #LivingHiFi
    Comment actions Permalink
  • Avatar
    Hi Brent
    I am sorry to hear that - is it just these two stations or is it all of iHeartRADIO. If it is just those two stations it is usually a service issue and should restore quickly. If it is all of iHeartRADIO, then please log out of iHeartRADIO from the More Music Menu. Then Select Help, Diagnostics and reboot your Bluesound Player from the bottom right.
    Once the Player is restored to ready mode (blue LED), select More Music and log back into iHeartRADIO and try again.
    If the problem persists, please select Help, Send Support Request and we will be in touch.
    Thanks for #LivingHiFi
  • Avatar
    Chris Walker
    Hi, I was listening to KFI in iheartradio at my desk and just performed the latest update and am experiencing the same issues, constant drop-outs and sporadic pops and squeals.
    Definitely related to the update.
    Chris
  • Hi Chris
    Please see my response... thanks
  • Avatar
    Chris Walker
    Followed your instructions, however the problem still exists.
    Just to be clear,I was listening the the same station (KFI 640) on iheartradio without any issues as all (I listen most of the day). I was prompted for an update and after the update completed the various dropouts and pops and squeals began happening. I am listening now and it is happening.
    Should be easy to duplicate if both myself and the other bluesound user is experiencing the same problem.....
    Chris
  • Hi Chris
    I spoke with our QA team here and they have identified a possible issue with iHeartRADIO. They have a possible fix and will be testing it over the weekend. If it passes quality assurance testing, look for an update Monday or Tuesday.
    We again apologise for the inconvenience and thank you for your patience.
  • Hi All
