How to use Volume limits (dB) setting
AnsweredHow should I be using the Volume limits (dB) setting? the available info and answers on your sites is not clear (that I have seen). Is there a page or article that helps users understand and optimize this for their system?
Thanks I did end up finding that page but it doesn't answer what the setting changes will do to the sound and adjustment if I alter one or both ends of the -90dB to 0db bar. Thank you! I do appreciate the quick response!
DT
No changes will be done to the sound.
I have my Powernode set at -20dB because i have sensitive speakers. One click on "volume up" is to high volume at night in standard settings, but with -20dB I have to click 3-4 times to get the same volume.-1
