Bluesound Node n130: Subwoofer
    The SUB-WOOFER port on your NODE is always active. Turning the SUB-WOOFER setting on in your NODE will enable an 80Hz cross over and send only frequencies over 80Hz to the analogue outputs allowing for more dynamic response from your speakers.
