Vault 2i Case becoming sticky.
  • Rinus Dost
    I had the same problem. Bluesound acts as if this is a first time occurrence when the they get these complaints. They offer to fix it but you pays heaps. Just go to a drugstore and buy de-naturized alcohol, use a rough cloth, wet it regularly and start to rub firm with the wet cloth. You can see when the sticky stuff comes off. Its a hard job and takes about an hour but worth while, your Vault feels smooth as baby’s bottom. You will lose the “B”logo on the front in the process but what the heck. Good luck.
