Need Firmware update for manual installation
Followed by 2 people
    Hi Patrick
    Your issue has been escalated to our Support Crew so they can provide options for you.
  • Patrick Robey
    Thanks, Seppi.
    I was logging back in to update my post here. I did find and download the update to a USB.
    The instructions say to press and hold the Pause/Play button with the stick inserted, and then plug the power back in. I did that, but nothing happened.
    I found another message here around bad power supply capacitors being a potential cause. I am going to try that route. I’d appreciate any other ideas you might have…….it’s poor timing to shell out $500 but I have my BlueSound going 18 hrs/day.
    Thanks
    Patrick
  • Patrick Robey
    Here’s a link to the page around a failed power supply capacitor:  https://yawesome.com/how-to/bluesound-node2-solid-red-light-fix
