    Hi Geir
    If you are not seeing any options in your Settings Menu, Your App is not speaking with the Bluesound Player likely due to network issues. Check your handheld device is on the same network. If it is, reboot your router, wait 5 minutes, reboot your player, wait 5 more minutes then try again. If problems still persist, then e-mail us at support@bluesound.com.
