Powernode edge-crossover
AnsweredHi guys, checking the available audio options table (https://support.bluos.net/hc/en-us/articles/360036429314-How-do-I-manage-the-Audio-Settings-on-my-BluOS-player-) I notice that the Powernode Edge has a "crossover" option but not a "subwoofer" option. I may not be understanding the inter-relationship between the two, but does this mean that the Edge has a low pass filter (crossover) but doesn't have a high pass filter (subwoofer). Does this mean that the Edge always sends full range to the speakers despite what the crossover is set to?
Thanks.
Hi Steve
Thanks for bringing the documentation error to our attention. We will correct it.
The POWERNODE EDGE has a subwoofer ON/OFF setting to enable the crossover and behaves just like its 'big brother' the POWERNODE. When set to OFF, the speakers play full range. When enabled, only teh SUB plays below the crossover point.
The SUB is always active.
