BluOS Controller app 4.x.x
Access Audio Settings
To access the audio settings of the Bluesound Player, perform the following steps:
Android/iOS - Access Audio Settings
, and select the required Player.
- Tap the context menu (3 dots).
- Tap Audio Settings. The Audio Settings screen is displayed.
The Audio Settings menu options vary depending on the model of the Bluesound Player. For more information, refer to our Help Center article.
Windows/macOS - Access Audio Settings
- In the BluOS Controller App, select Player Drawer. The list of connected players or groups is displayed.
- Select the required Player and select the context menu (3 dots).
- Select Audio Settings. The Audio Settings screen is displayed.
BluOS Controller app 3.x.x
BLS-KB16-901
In the Player Selection Drawer a Settings icon has been added next to the Player name to adjust Audio Output Settings and Tone Controls instantaneously. If the Player is a Secondary Player in a group, the gear icon is replaced with a context menu. Select Settings from the context menu.
Notes
- This menu is still accessible from the main Settings menu in the Navigation Drawer under Player
- Not all audio settings are available on all Players. Each Player has it's on specific type of audio settings.
