BLS-KB15-705
You can disable the LED on your Bluesound 2/2i Players as well as on the original Bluesound Node, Powernode and Vault. In the Configure Player Menu, select Indicator Brightness and set the option to Off. On Bluesound Gen 2 Players, you can also Dim the LED. To re-enable, set the Brightness to Normal.
Notes
- Dim is not available on the Original Bluesound Classic Players
