BluOS Controller app 4.x.x
View VAULT's Internal Storage Usage
To view the VAULT's Internal Storage Usage, perform the following steps:
Android/iOS - View VAULT's Internal Storage Usage
, and select the required VAULT.
- Tap the Home tab
> Settings button
> Music library > Disk usage.
- The Disk usage screen displays the following:
- Total disk space in GB
- Disk space used in GB
- Remaining space in GB
Windows/macOS - View VAULT's Internal Storage Usage
- In the BluOS Controller App, select the Player Drawer and select the required VAULT.
- Under the left Navigation Drawer, select Settings > Music library > Disk usage.
BluOS Controller app 3.x.x
BLS-KB14-502
In the BluOS App, select the Vault from the Player Selection Drawer using the icon in the top right corner. Once selected, open the Navigation Drawer by selecting the Bluesound Icon in the top left.
Select Settings, Disk Usage.
There, you will be able to read info about the Total Disk Space, Disk Space Used and Remaining Space on your Vault.
