BlueSound Hub surround sound.
BeantwortetHello, I was wondering if the bluesound hub supports dolby digital 5.1 or any surround sound. Id like to use it to connect my projector which is mounted on the ceiling to a pulse+ soundbar and two flex satellites without having to run wires from the projector to the soundbar.
Hi Sean
The Bluesound HUB does not do DOLBY decode. You will have to run a specialised HDMI cable to the SOUNDBAR+ directly.
