Problem with Bluesound Node Firmware - TOSLINK optical out doesn‘t switch off in standby
BeantwortetHello,
I have a problem with the current generation Bluesound Node. I use the device with my Bang Olufsen speakers. I want to connect the speakers and the Bluesound Node with the optical cable. Unfortunately, the optical output does not switch to standby mode and remains constantly activated.
Therefore, the speakers do not recognize that the device is turned off and they therefore remain constantly on.
Please correct this error with a software update and also switch the optical output on in standby mode.
Many Thanks.
mirco
3
Thank you. This is exactly the problem. Hopefully they will fix up. The post is 9 month old!! 9 month for an error in the firmware.
2
