delay between songs
BeantwortetI have two Pulse 2i and a large song catalog via a network share.
I recently updated all the software, speaker and controller and now I have a very long delay between songs.
it takes a good 30 seconds to start an album and at least 10 seconds between songs.
This did not happen before the recent software updates. Does not matter if I use a computer or a phone to launch the music.
I have reindexed the library, no effect
Anyway to adjust this?
rebooted all, no change. 35 seconds to start an lp, 10-20 seconds between songs,
this was not happening before the series of software updates in the last month
I run the speakers through a powerline ethernet because if I don't, the speakers get out of sync. The latest controller update removed my ability to use my IPhone to run the system. works on Android and on Windows
no change. If I use WiFi instead of Powerline, the two speakers get out of sync, even though the speakers are only one room apart and good WiFi connection in both rooms
there has been a series of software updates recently, at one point I had both reasonable start times and I could use my Iphone. Can I get pervious versions of the controller software?
