powernode volume issue
BeantwortetHello. This morning I had the powernode paired with my node and since then the volume level of the powernode is extremely low, no matter what adjustments I make. I have seen something about an issue with the latest software update. Anyone else experiencing this problem? I have also previously experienced the well documented problem where the volume level goes up dramatically in between play sessions.
Hi Dennis
Please select Help, Send Support Request in the BluOS App and follow the on-screen prompts so our Support Crew can review your player event log and assist with what you are seeing.
Thanks but I have tried all that to no avail.
