Android Tablet using bluetooth rather than wifi?
BeantwortetI have my Node hard wired and it works fine. I bought a really cheap Android pad to use as a controller and it works most of the time. The problem is my wifi router is afar and the tablet drops wifi sometimes. Is there a way to use the tablet bluetooth to control the node but not transmit the audio signal over bluetooth?
0 Kommentare
