Bluesound node use case
BeantwortetHello,
I am new to this blue* concept. I need to know if Node is right choice for me.
My scenario is:
1. livingroom with LS50 Wireless 1 -> I prefere to feed them via USB
2. work room with Topping DAC D70s -> also USB which is preffered source
How to make Node feed those two (or later maybe 3) devices via USB? I have no possibility to get Toslink/Coaxial or USB cable between rooms. Only Ethernet.
Currently I use Roon and Raspberry Pi4 as a bridge which is fed through ethernet from core.
Is something like that possible with Node?
Thanks. I was afraid it works like that 😔.
Can I than run Tidal on both at the same time? Without family account.0 -
Thanks for clarification. Then bluesound is not for me.
