USB output
5 Kommentare
  • EJK
    Thanks. I have to reconnect the usb dac I think because I do not see the option right now with using my other dac. Meaning I guess to see that option described in the link the usb dac has to be connected?
  • hung nguyen
    I don’t see this Select Output possibility on my BlueOS app either. Hence I have the same question as EJK.
    Would appreciate a reply from BlueSound Support.
    Thanks
  • EJK
    Once the usb dac is plugged in you can switch the outputs. I followed what is in the link. No usb plugged in then it doesn't show the switching option for usb.
  • hung nguyen
    Indeed !
    Thanks a lot 👍
  • EJK
    Now I'm running 3 external Dac's off the Node
