BS Node N130 no sound to Holo Audio Spring 2 L2
  • Adriano De Canio
    Thats the max sample rate on that input. Dont know if it shows that due to the USB connection.
  • Adriano De Canio
    I have checked with Holo and was advised i have the correct driver. Will check a different version and see if that works
  • Scott Lee
    Hi
    I have a Holo spring 3 L2, the firmware is 30.14 and usb gen 2.0, with the same issue.
    Which version firmware or driver did you change to?
    Thx.
