Pre-program Optical Digital Input 1 (TV mode) on remote RC1?
7 Kommentare
    Permanently deleted user
    Create a preset following these instructions, selecting the optical input as the source.
    https://support.bluos.net/hc/en-us/articles/360012637674-How-to-add-or-delete-a-Preset
  • Jürgen Lenzing
    Good to hear, but I've tried everything to set that option in the RC1 but I haven't succeeded so far.
    Is there a short description how I can record this?So, for example, under key number 10.
  • Jürgen Lenzing
    Thanks again for the answer.
    I'll read it through and try again tomorrow and I hope it works.
  • Jürgen Lenzing
    Thanks for your replies and the problem is solved, my thanks for that.
    The Optical Digital Input 1 source has been added to button 10 of the RC1 remote control after you have completed your instructions.
  • Ben Vet
    I have the same problem, looking for a solution to program the optical digital output under presets 1-10.
  • Permanently deleted user
    Optical input like the OP or Output?
  • Ben Vet
    Sound from my tv is optical output (from tv to soundbar). When I stream music (Spotify) I want to be able to switch back to optic input with the remote by just pressing a button.
