External Hard Drive Format
4 Kommentare
  • Cameron
    I recommend that you format the external drive to Linux ext 4
  • Alain DW
    Lossless
    Or Seppi, make good use of an obsolete laptop/desktop and install your preferred flavour of Linux.
    All free, no extra cost needed.
  • Cameron
    Sure, but if he can get someone else to format the drive to Ext4, then he can simply plug it in to the back of his bluesound device and use the drive as a NAS on his home network and it will be accessible from his Mac or pc
  • Roeligan
    You actually don't need someone with a Linux install. Use brew to install e2fsprogs and simply follow the steps in this post:
    https://www.reddit.com/r/applehelp/comments/5s6u2n/formatting_an_external_hard_drive_in_ext4_from_my/
    It also works for ext4.
