Pulse Sub Popping / Crackling noise
    Mark T.
    Sr. Support Crew Member
    Hi Sam,
    Something does sound off here but our Support Crew will need to take a closer look. Please select Help, Send Support Request in the BluOS App. In the brief description field please enter exactly as typed the following string (lowercase and with the underscores);
    _alldiscovered_
    This will send us the log files to all your players so we can check if there is a buffering or timing error.
  • Sam Gazzone
    Hi,
    I did as requested a couple days ago, will you email me with what you find? Thanks
