Crackling using Roon on C368 but not BluOS Controller
4 Kommentare
    Mark T.
    Sr. Support Crew Member
    Hi Briano,
    I suggest that you send a support request to support@nadelectronics.com. A member of our support team will reach out to you as soon as possible.
    Thanks for #LivingHiFi
  • Brian
    Lossless
    Thank you for the reply. On a hunch I reset the C 368 and updated it to the latest firmware it supports. The crackle has not returned.
  • Mark T.
    That's great news.
  • Alex
    In case this helps anyone, I had the same issue with my Powernode 2i and a factory reset solved it. At least for now, hope it doesn't come back.
