Bluesound Node 2021 coax output to external Dac
BeantwortetDoes the Node 130 output out of the Coax the same as it’s USB output - as in pass MQA out to an external Dac- if it does - what’s the preferred connection to a Dac from the Node?
Thanks for the confirmation Seppi - I intend to try out the new Zen one Dac Signature so will check it first to see if does decode MQA on specific inputs
