intermittent Low Volume output on node 2i
BeantwortetHas anyone had intermittent Low Volume output on node 2i? I'm 99.9% sure it was the node causing this issue.
Todd
Hi Todd,
Please double-check all your connections. If you have re-confirmed that its the NODE, please send support request to support@bluesound.com
Thanks for #LivingHiFi
