Turn off optical signal when Node N130 is in power save mode
BeantwortetIt would be great if the digital outputs (optical) would turn off when the Node N130 enters power save mode, as the active speakers other wise still thinks that a signal is passing through. Only solution right now is to turn off the Node N130 every time I don't listen to music.
Hi,
Thanks for your comment and rest assured that I will forward this to our developement/engineering team for a possible future update.
Thanks for #LivingHiFi
