What exactly is "Force Hotspot Mode"
6 Kommentare
    Mark T.
    Sr. Support Crew Member
    Hi Keith,
    Force Hotspot Mode clears/erases the current saved wireless configuration and removes your device from the network.
    To learn more - How do I reset my Bluesound Player to Hotspot Mode? – The Bluesound Support Crew
    Thanks for #LivingHiFi
  • Keith
    Thanks,But why would I need to remove the device from the network?......examples?.Thanks,Keith
  • Bjørn Ulvik
    If you move your player to a "new" network you could force hotspot mode, and be able to setup the "new" wireless network.
  • Keith
    Thanks for that explanation.Keith
  • milan kurfirt
    why does bsp200 have this option (some wireless option, or something with hotspot) when it always needs to be connected by ethernet cable?
  • Permanently deleted user
    I am sure it’s just an oversight, BluOS works on 80 odd different hardware devices and the majority of consume devices are both Wi-Fi and Ethernet enabled.
