Notice of firmware update (3.18.0) for NODE
11 Kommentare
    Bjørn Ulvik
    You will get an update notice for firmware if it's for your specific equipment.
    You will get an update notice for software (BluOS Controller) whatever your equipment is.
    Release notes:
    https://content-bluesound-com.s3.amazonaws.com/uploads/2022/04/BluOS_Release_Notes_3.18.7.pdf
  • Keith
    Thanks for the replies.
    One other question...what does the new desktop app 3.18.0 for the NODE contain?Thanks,Keith
  • Skip McDowell
    This is just a guess on my part, but it was probably just a change to the UI to allow for the new "Balance" feature.
  • Keith
    I am not positive,but I think that the new 'balance' feature is not pertinent to the NODE,lots of other models,but not the NODE....I could be wrong.Thanks,Keith
  • Keith
    The "NODE" I keep referring to is the latest version,third generation (model (N130) and I believe it came out in 2021.
  • Keith
    Sorry...don't know why I kept referring  to it as the "NANO". I fixed previous references.Thanks
  • Craig Jacko
    Do yourself a favor and don't update. There are serious problems with the latest releases.
  • Keith
    Could you elaborate on what "serious problems" there are associated with the latest releases?.Thanks,Keith
  • Craig Jacko
    1. Windows and MacOS controllers failing to load. This is the most serious problem. 2 of 4 total controllers for the platform do not work.
    2. Amazon music authentication issues.
    3. Qobuz playlists not loading
  • Keith
    Thanks...I did the firmware 318.0 last night,so I will keep a eye out to see if it causes any problems.Thanks,Keith
  • Ray Jazz
    Why did my Node2 do a long update one week ago? I can’t see it listed on the update.
    Since then I having problems streaming Qobuz.
