Wireless patio speaker options for Node/Bluesound
    Hi Ralf
    You always have the option of traditional outdoor speakers connected to a POWERNODE. Speak with your local Bluesound Dealer about options for you https://www.bluesound.com/stores/
  • Ralf
    well, my requirement is portability.
    So, then the Flex is the only option?
