Bluesound connection to an AV-Receiver
BeantwortetAV Receiver Onkyo RZ 820 2 x Mono Endstufen Anvance Acoustic XA220 an Onkyo für Stereo-Betrieb. Lautsprecher 7.1 setup Möchte den Bluesound Node 3 als Streamer in die Kette einbinden, um mich klanglich zu verbessern und statt über Bluetooth dann über ein festes Netzwerk die Musik genießen zu können. Habe momentan das Amazon Musik HD Abo ist aber ein anderes Thema Frage : Habe die Monos an Pre Out am Onkyo und da der Bluesound nur Ausgänge hat, frage ich mich, wie der Anschluss funktionieren soll. Wäre cool, wenn da jemand helfen kann. Zweite Frage wäre : Welcher DAC wird beim Anschluss dann angesprochen? Der Onkyo hat über PCM 24 bit / 192 kHz Und welcher DAC wäre da vielleicht besser ?
AV receiver Onkyo RZ 820 2 x mono power amplifiers Anvance Acoustic XA220 to Onkyo for stereo operation. Loudspeaker 7.1 setup I would like to integrate the Bluesound Node 3 into the chain as a streamer in order to improve the sound and to be able to enjoy the music via a fixed network instead of via Bluetooth. I currently have the Amazon Music HD subscription, but that's a different matter. Question: I have the monos on Pre Out on the Onkyo and since the Bluesound only has outputs, I'm wondering how the connection is supposed to work. Would be cool if someone can help there. Second question would be: Which DAC is then addressed when connecting? The Onkyo has 24 bit / 192 kHz via PCM And which DAC would be better there?
The choice is yours - you can connect the NODE to one of the analogue ins of your receiver or directly using COAX. The COAX output will bypass the onboard DAC of the NODE N130. Once connected set the volume output to fixed audio under Settings, Audio in the BluOS App.
Try both the AV DAC using the COAX out of the NODE or the NODE's own DAC using analogue out and let your ears decide which you prefer/
